  • 1.  MIRA and Dashboard
    Posted 06-28-2021 13:25
    Hello!
    I've been trying to create a custom panel where I could place the MIRA playlist on it but when I connect the MIRA it doesn't show anything on my DashBoard computer. It shows it's connected but nothing appears. I'm not sure what is wrong I already tried to disconnect and connect again but it didn't work.
    Thank you!
    Bruna Gregorio
  • 2.  RE: MIRA and Dashboard
    Posted 06-28-2021 15:20
    Did you have any luck connecting your Mira to the Dashboard? I know that is something we are trying to do.
    Ryan Gonzales
    ALTITUDE SPORTS & ENTERTAINEME
  • 3.  RE: MIRA and Dashboard
    Posted 06-28-2021 15:59
      |   view attached
    Attached is a quick start guide for the Abekas OGP service and DashBoard setup.
    Hope this helps.
    Marsha Opacic
    Attachment(s)
  • 4.  RE: MIRA and Dashboard
    Posted 06-29-2021 10:14
    Hi Marsha!
    Thank you so much!
    It is working now, I didn't have the Abekas OGP on this computer, but it's all working.
    Have a great day!
    Bruna Gregorio
  • 5.  RE: MIRA and Dashboard
    Posted 06-29-2021 12:01
    Hi Marsha!
    I actually have a question about MIRA, I've been wanting to open the Playlist Editor and the Channel's playlist on my DashBoard computer but I'm not really sure how to do that of if even it's possible. I can only open on the Mira Explorer. Could you help me please?
    Bruna Gregorio
  • 6.  RE: MIRA and Dashboard
    Posted 06-29-2021 12:06
    Hi Bruna,
    Playlists cannot be seen in DashBoard. However, there is a way to build a playlist within DashBoard since DashBoard can see the clips within the Clip Library. Unfortunately, I'm not a DB expert, but if you want to email me directly, I may be able to point you in the right direction for help.  mopacic@rossvideo.com
    Marsha Opacic
  • 7.  RE: MIRA and Dashboard
    Posted 07-02-2021 09:43
    Hi Marsha,
    I'm back because I'm facing issues with Mira, so it's not working anymore, two days ago it was working just fine, yesterday it wouldn't open on the first try and today it isn't working at all. As I showed you before the sub-nodes Replay and Explorer don't appear for me even though it's green and it says "active".
    I'm not sure if it has anything to do with it but when I try to run the AbekasOGP on Mira and on my DashBoard computer it shows me the error on the image.
    Thank you!
    Bruna Gregorio
  • 8.  RE: MIRA and Dashboard
    Posted 06-29-2021 10:16
    After downloading the Abekas OGP and following the steps Marsha sent, it's working now.
    Bruna Gregorio
