  • 1.  Frame Sync settings not remembered between reboots with version 8
    Posted 02-05-2014 21:38
    I upgraded our Carbonite 2M to version 8 the other day. We have one source that doesn't take genlock, so I need to use a frame sync on it. Unfortunately, since upgrading, each time we power the mixer on the frame sync is not applied and I have to reapply it. I'm not using MiniMEs, so all my frame syncs are available. Is there something I can do about it other than getting an external frame sync (which I'll need to do if I want to use the MiniMEs)?
  • 2.  RE: Frame Sync settings not remembered between reboots with version 8
    Posted 02-06-2014 01:38
    I've downloaded v8 but won't do the upgrade until after Tuesday's show. Something James said caught my eye regarding FSFC and MiniME. Does the MiniME eat up a FSFC resource somehow?
  • 3.  RE: Frame Sync settings not remembered between reboots with version 8
    Posted 02-06-2014 02:00
    Yes, it does eat them up. It's bundled with the 8 DVE mode.
  • 4.  RE: Frame Sync settings not remembered between reboots with version 8
    Posted 02-06-2014 04:51
    Now I see. Real glad I bought a Plus frame so I had the 16 FSFC and 8 DVE. Hopefully the 4 MME's will just be in addition.. Btw, I've had great success with the Grass Valley G1's as external frame sync's
  • 5.  RE: Frame Sync settings not remembered between reboots with version 8
    Posted 02-07-2014 13:31
    This makes me nervous about updating to v8. We rely on frame sync and I'd hate to have to reset it after every restart.
