Sounds like it is in a weird state.
You could restart the panel application. In the positioner area hold down the three buttons Hold Link Clear and then press the button on top of the positioner.
This will restart the panel application. Takes about 3-5 seconds and you should then be fine. This has no impact on the frame or what is on air will not change.
#Vision
