  • 1.  Carbonite Macros
    Posted 12-24-2011 19:25
    Hello
    I was building a Macro which was recalling an effect on MLE 2 in Preview and then cutting it to line. It is a PIP with three boxes using three keyers. I am using MLE 1 PGM and Preview to switch the input to two of the keyers however i can not get the Macro to change to MLE 1 . I have tried using the "State" in the "Special Functions" but have had no luck.
    Any information would be greatly appreciated.
    Kind Regards.
    Bruce
  • 2.  RE: Carbonite Macros
    Posted 12-24-2011 20:59
    HI Bruce,
    This seems kind of strange. Any Chance you could send me your setup files?
    Just save them to usb (you will be able to chose from set0-9 and do a save all) Then put the usb into your computer (or FTP into the switcher using user password as the login info) in the /switcher directory you will find your setup files that you saved take the whole set folder and zip it up then email it to me.
    loreilly@rossvideo.com -- I can have a look at it after the holiday break. If this is urgent and needed for next week sometime let me know and I will head into the office and try to have a look at it sooner.
  • 3.  RE: Carbonite Macros
    Posted 12-24-2011 21:01
    Oh one other question really quick -- have you tried doing a recall on MLE 2 and then a separate recall on MLE 1 in your Macro? It might fix your issue to do that before you do the Cut function.
