  • 1.  Timing Issue
    Posted 08-03-2013 21:47
    I am experiencing a timing issue with my Vision 3 when switching between memories or MLEs with either fly keys or chroma keys. For example, when I build several memories where I have keyed a camera and a fly key over a still from the global store, and I switch between the memories, there is a delay between still, the fly key and the chroma key. The result is a staggered, and flashy switch where the keys are delayed by a frame, each. It is essentially unusable. Anyone else experience this? Any workarounds or fixes?
  • 2.  RE: Timing Issue
    Posted 08-05-2013 22:11
    what your seeing is normal. Elements have to be turned on or off for a frame to change the key settings. you will need to recall these elements in an off air MLE and then take them to air.
    #Vision
