  • 1.  How to reset transition limit
    Posted 07-20-2014 05:49
    Hi , Please guide me how to reset Transition limit of fader in QMD Vision Octane 2 MLE switcher.
    narayan
  • 2.  RE: How to reset transition limit
    Posted 07-20-2014 17:24
    To do this is simple move the fader arm to the desired location and then press the trans limit button.
    if your trying to do this live and not before the show has started first press the Trans Preview button so that you see the transition in "Preview" move the fader arm to desired location and then press the Trans Limit button. Now turn trans preview off and you will be able to enable trans limit button again to run the desired location.
    #Vision
