  • 1.  MLE Still Stores and OverDrive
    Posted 12-21-2016 02:53
    I am trying to get the MLE 2 Still Stores to work as a Device on Ross OverDrive.
    I built a switcher memory with MLE 2 Still Store 1 keying over a crosspoint.
    I recently added the crosspoints for the MLE 2 Still Stores (1-4) to the Bus Maps, but when I try to add those crosspoints to a new Still Store Device in OverDrive, I get an error saying that those crosspoints aren't configured as Still Store devices. They also show up as "none" instead of "MLE 2 Chan X" on the OverDrive Template Editor.
    I also run into an issue selecting the stills -- I am not seeing stills I recently added. Is there a way I can make it so I can only select stills from a specific directory? I created one called "News GFX" that is separate from the directory we use for interstitial wipes.
    We are using an Acuity with Version 4.0g, and Ross OverDrive version 15.8.
  • 2.  RE: MLE Still Stores and OverDrive
    Posted 12-21-2016 18:19
    Hi Nate,
    Can you confirm the specifics of the OD version that you're using? I see 15.8, but I'll need the next "dot" number, as well as build please.
    -Mike
    #Acuity
  • 3.  RE: MLE Still Stores and OverDrive
    Posted 12-21-2016 20:37
    We are using 15.8.3, Build 87.
    #Acuity
