  • 1.  Media-Store Animation Autoplay Behavior
    Posted 01-31-2013 20:16
    What are the specific actions that can trigger an animation to actually autoplay?
    I currently have an animation loaded in M1 with the attribute set to autoplay. When I cut to M1 on progam, or cut a key to air that's using M1, the animation doesn't play. However, if I have M1 live on the program bus, or the key live, and then reload that media, it autoplays.
    Is this the correct behavior? I expected, based on the manual and conversations on this forum, that whenever I took the media "to-air", it should autoplay. I have made a custom control as a work-around, but I'm wondering if something is wrong with the autoplay feature.
    I am on 7.1 software.
    Thanks,
    David
  • 2.  RE: Media-Store Animation Autoplay Behavior
    Posted 01-31-2013 22:02
    Nevermind. It works as expected after a switcher reboot.
  • 3.  RE: Media-Store Animation Autoplay Behavior
    Posted 02-28-2013 05:16
    I'm having a problem with Auto Play that didn't get fixed on a power cycle.
    I created a Media Wipe the old fashioned way using Key 4 and a custom control. The custom control changes Key 4 to Media Store 2, selects U1.001, then cuts it on. There's a 15 frame pause then there's a BG Cut, then another 15 frame pause before cutting Key 4 off and changing it back to CG4. This works like a charm on MLE2, but when I built the exact same effect on MLE1 it brings the animation from Media Store 2 on at the midpoint and does not play it. The rest of the custom control works. Why should this work on MLE2 but not on MLE1? I have the animation set to Auto Play, as evidenced by the fact that it works in MLE2.
  • 4.  RE: Media-Store Animation Autoplay Behavior
    Posted 03-27-2013 15:46
    David,
    I see that this is an old post so I am sorry for the delay.
    I am curious as to why you would create a MediaWipe manually, if you use the MediaWipe transition feature it will work every time, you can put it in a Custom Control and it doesn't use an MLE keyer so you still have 4 keys.
    What version of software are you running?
    Nigel
  • 5.  RE: Media-Store Animation Autoplay Behavior
    Posted 03-27-2013 17:05
    Nigel,
    The reason I built it this way is because the built-in media wipe doesn't allow you to wipe over a key. You can only take a key out or put one in with the media wipe.
    This way I can wipe video and hot read a lower third underneath the wipe.
    I have it as a custom control, so it's still just a button push, and we very rarely use more than one keyer at a time anyway, so using Key 4 isn't a big deal.
