  • 1.  Need help with animated 2/4 box.
    Posted 12-03-2013 20:06
    I need to make 2/4 box's in MLE 1. those box should have a background or CG. for example: in
    box 1: cam1
    box 2: cam2
    box 3: cam3
    box 4: cam4
    Background: CG
    i need those box's individually squeeze or expand on full screen. need some guideline to make this. is it possible through custom key or onky with the keyers or there are both options?i want to do this with vision 2M.
  • 2.  RE: Need help with animated 2/4 box.
    Posted 12-04-2013 05:54
    You can make the "base" memory with you 2 box or 4 box.
    Then you could make 4 other memories (2 for the 2 box) where you make each of the boxes full screen but leaving the others in the small position. with the full screen also make sure you set the key priority accordingly as well.
    Then you can use the EFF Dissolve feature to be able make them move from the base memory to these other memory positions.
    #Vision
  • 3.  RE: Need help with animated 2/4 box.
    Posted 12-04-2013 13:14
    Mr. Les
    Thanks for your reply. If you could post a video about this it would be more clear and helpful.
    Thank you again.
    #Vision
  • 4.  RE: Need help with animated 2/4 box.
    Posted 12-04-2013 18:07
    I am traveling this week and will not be able to get to a video until I am back in the office next week.
    #Vision
  • 5.  RE: Need help with animated 2/4 box.
    Posted 12-05-2013 19:47
    No problem. i can wait. thank you.
    #Vision
  • 6.  RE: Need help with animated 2/4 box.
    Posted 12-18-2013 14:11
    Hi Mashroor,
    Sorry for the delay but we had the Demo Room booked and then I needed find a camera. This video is kind of low end but I really wanted to get you something before I headed out on another trip.
    https://www.dropbox.com/sh/5efa5dan3qs8taj/kFSI1SuR2V
    #Vision
  • 7.  RE: Need help with animated 2/4 box.
    Posted 12-20-2013 00:40
    Hi Les,
    Thank you so much. This is very helpful. I'm going to try this today. You seems travel a lot. Do you have any plan for trip in Bangladesh? If you then please let me know. I'll like to meet you.
    Best regards
    Rokon
    #Vision
