Ok, so I had another topic about a week ago, and it's kind of the same problem but this is the underlying problem, as to why the auxes wouldn't save. The global store memory module actually uses an old file when the switcher is shut down or rebooted. I've made changes to a store and then stored them by hitting store all, then bank+0, then 0, then enter, and I always hit accept new name just in case. So then I've tried restarting the global store module and that doesn't affect the stores at all, and then force-upgrading all the modules doesn't reset it either, and after storing a store once, I can flip between stores and it even shows me the changes I made. It's just when it's shut down or restarted that it loses the changes. I actually did try setting the auxes with a custom control and it only saves temporarily. The store isn't locked or anything, it just won't save. The last time it would was probably the beginning of July. On the side, this switcher is still on version 10.1i and won't take any updates. It just says build 16v1d received, now verifying integrity. Then a second later it comes back with error: file failed to unpack.
