  • 1.  Crossover 12 DVE and After Effects
    Posted 12-22-2015 11:24
    I use the Crossover 12 at church. I'm trying to create a simple DVE wipe with a snowflake. I use After Effects and have created the wipe in it, but it's only working within AE since the video it's wiping has to have an alpha matte attached to it. But since I want to use this transition in live production I don't need the videos. How can I just save the transition and apply it to the crossover?
  • 2.  RE: Crossover 12 DVE and After Effects
    Posted 12-22-2015 14:34
    When you build your "wipe" effect you need to not have the video tracks -- just the Animation and Alpha. Then use the media wipe feature on the CrossOver units. Now if your trying to match the alpha wipe to live Video and the Video has to move with a DVE -- that is not available.
    #CrossOver
  • 3.  RE: Crossover 12 DVE and After Effects
    Posted 12-23-2015 05:30
    Thanks.. I'm finishing up a few transitions tonight. I have a service tomorrow night. Any suggestions on loading the TGA files from USB drive? I have never tried this before but I do have a manual and have briefly looked over it.
    #CrossOver
  • 4.  RE: Crossover 12 DVE and After Effects
    Posted 12-23-2015 14:48
    yes the manual has all of the information on how to use a Media Wipe. It's pretty straight forward. Plus there is a video in the Carbonite U about Media Stores that does cover the similar operation as CrossOver - just no Audio or the Web Interface / DashBoard GUI as you will have to use the panel menu.
    #CrossOver
  • 5.  RE: Crossover 12 DVE and After Effects
    Posted 12-28-2015 06:26
    Clean the USB before. Format
    #CrossOver
