Hi Amit,
Use the DVE to Blur the Video -- under the preprocessor effect you have the Defocus option. Turn it on and then use the control to Defocus.
put the same video on the BKGD bus and then in the Keyer that is defocusing the video you can now use the DVE to also Crop down to only the section you would like to Blur.
#Vision
