  • 1.  Crossover 12 Solo Without output Tally
    Posted 08-24-2012 21:10
    None of the tally output switches, my question is, I have to reset the switcher to fix it?, Or all over.
  • 2.  RE: Crossover 12 Solo Without output Tally
    Posted 08-27-2012 15:48
    You may want to reboot the switcher and if they still don't work (you could use a MultiMeter to test that the contacts close) it may be that too much current was run down the line and damaged these. At that point you should contact Tech Support. +1-613-652-4886
    #CrossOver
  • 3.  RE: Crossover 12 Solo Without output Tally
    Posted 08-27-2012 19:52
    Ok. Thanks Les, restart the switcher and everything worked again.
    #CrossOver
