  • 1.  Aux Transitions
    Posted 10-05-2015 13:21
    Hello guys, Quick question.
    How can I make an Aux do a transition/Fade?
    Example: I have a Macro that takes Aux 1 that has Me3 Still 2 and changes it to Me3 Still 1. But it cuts and i want a fade.
  • 2.  RE: Aux Transitions
    Posted 10-05-2015 13:39
    Hi Chris,
    Your going to have to configure some outputs to be AuxKeys. If you don't setup as an AuxKey then you will not be able to dissolve. This will require that two outputs in specific groups be assigned together to make a A/B bus workflow. Think of it like an ME Bkgd/PST and doing a dissolve.
    Previously posted here in the forum this is the Video to a "config" and explanation of AuxKeys:
    https://www.youtube.com/watch?v=WDTsQ4-Qbe8
    Then I did a small addition of using the AuxKey in a few different applications and methods:
    https://www.youtube.com/watch?v=ogpAkXENeoU
    #Acuity
  • 3.  RE: Aux Transitions
    Posted 10-05-2015 14:56
    So I watched the video and I do not have the Configuration for the Aux key setup like you did. I'm using the Acuity V3.1a
    #Acuity
  • 4.  RE: Aux Transitions
    Posted 10-05-2015 15:59
    The configuration steps are basically the same on Acuity as they are on Vision (used in the video). Where are you having an issue?
    Are you working on a Multiplanel system and trying to access from a Satellite panel that may not have Menu permissions enabled?
    #Acuity
