This is my order of operations:
1. I hit M1 on the program bus.
2. Browsed for the 90 frame targa sequence on the USB and loaded it
3. Hit Next to change the attributes
4. X pos - 0, Y pos - 0, Shaped - no, Looping - no, Reverse - no, Autoplay - yes, Speed - x1, CutFr - 90fr, GPO - none, GPOFr - -1fr
5. Hit Media on the transition side
What do I do next?
I just want to go from a camera to camera, don't need to cue anything besides the animation. Should I be cueing M1 on the Key bus? There is no key, it's just an RGB transition wipe. If I put it on Key 1, and Auto Trans, it doesn't seem to cut to the other camera after the 90th frame.
