Hi Michael,
I am pretty sure that the KiPro have Network interfaces and also a HTTP post based command protocol. You should be able to create your own custom application to support this. There are examples for getting started in the DashBoard U section of the DashBoard Product site on the Ross Video website.
You will note that since DashBoard is free and the "OGscript" language is based on JavaScript you should be able to search of examples of code snippets as needed in the Java world -- so for example if I was trying to Trim text I could search for "Javascript Text Trim example" and I will find lots of examples on how to do it.
If your looking for custom development as you do not have the experience in your team then you can always look at having Ross Video Creative Services develop these custom applications for you. We do offer these services and based on a scoping of the solution would be able to provide a cost and schedule to you. We now have a small team that is dedicated to this.
