  • 1.  Using Effects Dissolve
    Posted 08-27-2014 16:24
    Hi Guys!
    I have been working on a two box grid with movement via the effects dissolve.
    My issue I am having is, when I recall any of the memories for this two box grid my audio channels close. This happens when I recall the memories manually, by running a custom control on the Vision and when recalled by a template in Over Drive. Is there a setting somewhere that I might be overlooking when saving these memories?
  • 2.  RE: Using Effects Dissolve
    Posted 07-10-2017 13:39
    I have had this same issue..is there a fix?
    #Vision
