Your IP should not matter. Your sending to the Switcher and its IP should stay the same.
If your building custom panels you can always use the internal hosts table so that you assign a device to all the functions not an IP address each time.
Then your able to edit the host table in the custom panel to the new IP addr as of the switcher.
#Acuity
