I would like to send simple raw hex to a RS232 serial 9-pin device plugged into REMOTE8.
I have a hex string and I've programmed Custom_Device_Command(1)
CUSTOM1 [PLAY] with the follow hex bytes:
[I]63 31 0d 0a 31 35 30 77 0d 0a 63 32 0d 0a 30 77 0d 0a 63 33 0d 0a 30 77[/I].
Should I use the [PLAY] command tag or something else?
I tried to create a custom device in Com_Setup but seemed to be missing CUSTOM1 as an option. Do I need to create a VTR device to use the [PLAY] command tag even though the device is not a VTR?
Also, what the easiest Custom_Control to fire off the hex command?
Any advice would be appreciated.
