  • 1.  GPIOs not firing with 7.1?
    Posted 01-17-2013 00:31
    Hi Les and Nigel,
    I upgraded our 2M to 7.1, and since then none of our GPIOs are working. I've checked that they're still set up, and they are.
    Any suggestions of what I should try?
    James.
  • 2.  RE: GPIOs not firing with 7.1?
    Posted 01-17-2013 13:35
    Hi James,
    It should work just the same. Please contact techsupport and work through trouble shooting with them so that they can get you replacements if needed.
    I would only suggest you disable the GPIO and then reconfigure them.
  • 3.  RE: GPIOs not firing with 7.1?
    Posted 01-20-2013 23:10
    Hi Les,
    Disabling and reconfiguring worked.
    Thanks,
    James.
