I am trying to copy the 2nd Channel from a 2 Channel Fly Key (2 DVE Boxes sharing 1 Keyer) to a BKGD Bus.
For example, I am trying to Copy MLE 2 Key 1 Channel 2 to the MLE 2 BKGD Bus. When I use the Copy Buses feature, it always copies MLE 2 Key 1 Channel 1, even if I have MLE 2 Key 1 Channel 2 "Selected" on the Key Bus.
Is there a way this is possible, or will I never be able to copy Channel 2 from a Keyer to a BKGD Bus?
-Nate
