I was wondering if it would be possible to make a code in overdrive that allows me to select 2 or 3 crosspoints for separate auxbuses.
Set up:
We have three monitors placed together. The individual monitors can be set to one of three auxbus feeds we have set up at the moment.
Typically they're all set to feed the same aux bus but in some cases they'll ask for a separate thing in each monitor. To achieve this we typically code a shot that we set a cross point for then use custom controls to for the other monitors.
Thanks in advance
