I just about had a heart attack tonight.
So, I wanted to experiment with my own switcher set, and decided that saving over a default with the ALL setting would be safest. So, I did. I then saved ALL to a new switcher set, and then made some new custom controls, and then saved those out as well, again using the ALL setting.
Afterward, I wanted to make sure I could get the board back to our station's default setting, and loaded up the set I saved it to, and loaded ALL settings. That was when the board crashed, and I had to reset the board from the CPU. Powering off just the board was not enough. So, when the board came back online, and I loaded ALL once again, it worked that time, and got things back to working order.
I am now nervous about loading and saving settings, but I'm thinking it was the ALL setting that may have done the harm, causing a lock up when (perhaps) the INST settings were recalled.
All I am really wanting to do is save my own MEMS and CUST settings, and I'm thinking if I were to try it again just saving using these options that I wouldn't cause a crash again.
We are also using software version 6.2.0.7650, and am wondering if a software upgrade would help. Also, our IT person wanted to make sure if we did upgrade the software, if there were any possibility of making anything connected to the board incompatible, or any other concerns we need to know about, before making such an upgrade.
