Last week, we changed out the switcher head of the 2MLE Carbonite. The only setting that I changed was turning the "follow" to OFF. I run the switcher with MLE1 on top and MLE2 as a pgm/pvw bank. While I was setting up the show, (and waiting for the 150 frame TGA sequence to load for a transition), I left to use the restroom, when I returned the MLE SELECT was no longer in the state that I left it (MLE2) it jumped to (MLE1). Of course I chalked it up to someone messing with the switcher while I was gone, but no one did.
Last night
DURING PRE-PRO FOR A SHOW this occurred again. I was not technical directing, however, the technical director I had was not even touching the switcher at the time this occurred. He and I were talking about I had setup his switcher.
Is there a setting somewhere I need to check? The switcher get powered down after every event since it is in a mobile tv truck. It has happened while both connected to shore power and generator power. I am at a loss, any thoughts?
