Hello All,
I'm mostly from a Sony switcher background and am now using a Ross Carbonite and Ross Vision switchers.
I see the same problem on both switchers meaning I see no way to delete memories.
On Sony switchers, deleting memories is very simple but it seems with Ross you cannot remove memories from the switcher after they are loaded - you can only load over them (which is very different from deleting a register).
Am I missing something here?
Thank you All
