I have fount with Version 8 and above that the memory SAVE will reset the MLE activate button. If recalling a memory that has both MLE and MME functions and you hit the SAVE button first then the RECALL button it will turn off the recall of the MLE and leave the MME'S on. This has cause some bad recalls. The SAVE button and RECALL button should not reset the MLE or MME activate buttons.
