  • 1.  Ross Tally Protocol Program Numbers
    Posted 02-02-2015 19:10
    Is a Ross Tally Protocol reference document available for download? We need a 'Program Numbers' reference. Our multiviewer is expecting a specific Program Number for each tally from the Ross Protocol.
  • 2.  RE: Ross Tally Protocol Program Numbers
  • 3.  RE: Ross Tally Protocol Program Numbers
    Posted 02-02-2015 20:53
    Thanks Les! And great job on the Vision switcher University courses you posted recently.
    #Vision
  • 4.  RE: Ross Tally Protocol Program Numbers
    Posted 02-17-2015 16:13
    Is it possible to use the Vision feature "tally on GPI' to trigger a serial tally to a Harris multiviewer? I've got a tally number defined no the multiviewer, a GPI on tally defined on Vision, and GPI control enabled in the Vision. When I close the GPI, no tally is activated.
    #Vision
  • 5.  RE: Ross Tally Protocol Program Numbers
    Posted 02-17-2015 16:18
    Do you have the GPI enabled in the remote enables menu?
    Home menu second screen. Remote enables.
    #Vision
  • 6.  RE: Ross Tally Protocol Program Numbers
    Posted 02-17-2015 16:22
    Yes, Remote control is enabled. in fact, if i define the GPI input as a cut or auto trans, i can activate those features on an MLE, so i know the GPI is working as intended. I also created a Custom Control to 'simulate' the GPI input for testing. The 'tally on GPI' through the serial tally won't fire. I may have a software configuration problem.
    Do you have the white paper that shows what all the 'Program Numbers' from the Ross tally protocol are? The paper you linked to earlier didn't have that information.
    #Vision
  • 7.  RE: Ross Tally Protocol Program Numbers
    Posted 02-17-2015 16:28
    Oh. No that won't go out the serial tally that is for triggering a physical Tally not setting a source as on air.
    #Vision
  • 8.  RE: Ross Tally Protocol Program Numbers
    Posted 02-17-2015 16:31
    Physical tally is a tally that is hard wired to the Vision panel?
    #Vision
  • 9.  RE: Ross Tally Protocol Program Numbers
    Posted 02-17-2015 16:51
    Yes
    #Vision
