Check the Quick start guide. If I remember correctly Tally 6 (pin 7) get's it's common from a different pin (31 I think) than tally 1-5. I have seen people make this mistake before (including me), I do believe it won't work unless it has the correct common's, I could be wrong.
Maybe try that, Good Luck.
