I'm running a dbx with moving bkg out of media store and it's 300 fr so takes a little bit to load when I first drag it over. I was told that once you load it, it stays in the cache unless the switcher is reset and doesn't need to reload all 300 fr every time. At this point, every morning I come in I have to reload it from scratch. Did I misunderstand?
Also, is there a way to delete errant files out of the media manager? Such as captures or animations we don't need. When a file was deleted from the drive, it didn't remove it from the media store database and this caused a problem with media store playout of another file.
