  • 1.  17.3 changed still store password?
    Posted 08-29-2015 14:18
    Hey Les (and others),
    Since we upgraded to 17.3c last October, ftp/webdav access to our still store has not been working. The password was always the default "user" & "password". I did not change the password as part of the upgrade. I can still access the upgrade/system status page using these credentials. Can you offer any assistance on how to reset the still store to allow access?
  • 2.  RE: 17.3 changed still store password?
    Posted 08-29-2015 19:28
    With all of the changes to WebDAV authentication in Windows 7 onwards this has become a very flaky supportable protocol.
    I would recommend that you switch to using FTP. You can MAP a network drive the same way but instead use FTP and the IP address of the switcher.
    #Vision
  • 3.  RE: 17.3 changed still store password?
    Posted 09-01-2015 12:45
    We access the still store from 2 computers. One with XP and the other a mac, so I'm not so sure it's related to Windows7. I'll try FTP later this week.
    Thanks for the help.
    #Vision
  • 4.  RE: 17.3 changed still store password?
    Posted 09-01-2015 13:19
    Also, I meant to ask if there is a newer version of the firmware than 17.3c. 17.3c has been mostly solid, but I had a situation this weekend that made me wonder if we need to do another update.
    ME1 Keyers were not keying properly - Chroma key appeared at half transparency, Self keys weren't working correctly either. This was resolved by a system restart. After that reboot, I couldn't modify or save anything. Custom controls couldn't be swapped/moved and I couldn't create new ones. Disk and USB wouldn't save or load either. Memories would store, but I couldn't save the vision files. Had to reboot for that too. After the second full system reboot and a third panel reboot, everything worked.
    #Vision
  • 5.  RE: 17.3 changed still store password?
    Posted 09-03-2015 14:49
    Yes contact Tech Support as we are now into Version 18.1 I believe.
    #Vision
