Hi Everyone,
I am trying to connect an RCP-ME panel to our carbonite black frame for crosspoint control.
The hardware setup is as follows (all static ip):
Carbonite Black >> ethernet >> switch
RCP ME >> network switch
NK-IPS >> network switch
NK-IPS >> Tbus 1 >>NK-NET apapter >> network switch
I don't use a carbonite panel in my setup, so in order to add the aux bus panel to the system I borrowed a 2ME panel and followed the instructions on the aux bus setup guide - using the network address of the IPS on port 5000, and switching on level 2.
Whenever I try to assign either crosspoint or destination values to the RCP - I get "no resp" from the LCD, as if to say it's not connecting to the carbonite. The current state of the RCP-ME is illustrating input 1 to all outputs which is certainly not correct.
What am I missing here?
Any assistance would be greatly appreciated.
cheers.
