  • 1.  RossTalk connection using applescript
    Posted 01-20-2015 05:35
    Hello Everyone,
    I want to trigger keys using a applescript. has anybody done this? and if so do you mind sharing your code.
    wanting to setup the applescript to remote trigger the key over my network.
    I have a crossover 12.
    Thanks,
    Brad
  • 2.  RE: RossTalk connection using applescript
    Posted 01-20-2015 23:16
    CrossOver Does not support RossTalk. You can use the GVG 100 Protocol over ethernet using the gvginject LUA commands.
    info can be found in this document
    http://www.rossvideo.com/pdf/cutsheets/crossover-interface/GVG100-Commands(4802DR-401-03).pdf
    #CrossOver
