  • 1.  New Version 6.1
    Posted 05-25-2012 13:39
    Went to down load 6.1 but it still is showing 5.1 on the download page.
  • 2.  RE: New Version 6.1
    Posted 05-25-2012 13:48
    Hi Robert,
    I just double checked the download page and everything seems to be up to date. There's a slim chance you may have to clear your cache.
    Let me know if it's still not showing up...
    Frank
  • 3.  RE: New Version 6.1
    Posted 05-25-2012 15:09
    This is what is showing up when I click the download page.
    http://www.rossvideo.com/software/carbonite/Carbonite_1_1M_2M_v5.1.0.6078.zip
    It is showing 5.1. That is what I have in my switcher now.
  • 4.  RE: New Version 6.1
    Posted 05-25-2012 15:12
    use this link and you will be ok http://www.rossvideo.com/production-switchers/carbonite/software.html
    I did it and is working ok
  • 5.  RE: New Version 6.1
    Posted 05-25-2012 15:17
    Hi Robert,
    Have you tried clearing your cache? In the meantime, here's a direct link to the file:
    http://www.rossvideo.com/software/carbonite/Carbonite_1_1M_2M_v6.1.zip
    Let me know if you need anything else.
    Frank
  • 6.  RE: New Version 6.1
    Posted 05-25-2012 15:22
    There is a problem between here and Canada, I did click on the down load page and then the software and came up with the error page not found. I just got your link and that did work. Thanks
  • 7.  RE: New Version 6.1
    Posted 05-25-2012 15:27
    If you have a free minute, sent me your coordinates to fgrenier@rossvideo.com and we'll get to the bottom of the issue. :)
    Frank
  • 8.  RE: New Version 6.1
    Posted 05-25-2012 15:47
    Ok. After reading you last memo I decided to use internet explorer. that worked just fine. The problem I guess is with my Fire Fox. Thanks again.
  • 9.  RE: New Version 6.1
    Posted 05-25-2012 16:09
    Robert what Frank was trying to point out is that in the browser you have to "clear the cache"
    in firefox under tools click on clear recent history and only select your cache.
  • 10.  RE: New Version 6.1
    Posted 05-25-2012 16:20
    Again thank you for all your help. There was not problem with Internet Explorer but Fire Fox I did have to clear the cache. All is well now.
