  • 1.  Still another multiviewer question (!)
    Posted 05-21-2013 20:48
    I'm looking at the manual for the Crossover 16, version 4.0; on page 2-7. I see that a multiviewer may switched to either Pgm2 or Prview outputs; that makes sense. The note on the right side of the page says, "the MultiViewer layout is configured independently for each output".
    Does this mean that I can set up the Pgm2 output to show one group of sources and the Prview output to show a second group of sources? I'm definitely misunderstanding something here, since this seems to conflict with other language that suggests only a single multiviewer display.
    -- Jeff
  • 2.  RE: Still another multiviewer question (!)
    Posted 05-21-2013 23:48
    Hi Jeff,
    No there is not 2 MutliViewer heads in the system. What that means is that you can chose to display it on either output or even both. Each output is independent in setting wether you view the MV or its standard type.
    #CrossOver
  • 3.  RE: Still another multiviewer question (!)
    Posted 05-22-2013 12:46
    Thanks -- I was pretty sure all of the Crossovers were alike in that respect, but that "layout is configured independently" line made me wonder.
    -- Jeff
    #CrossOver
