  • 1.  Playing clips as animated wipe
    Posted 06-17-2016 20:00
    Wanna use playback server for an animated transition. Is there a specific format the clip must be to have the alpha?
  • 2.  RE: Playing clips as animated wipe
    Posted 06-17-2016 21:04
    What is the playback server that you are using?
    #Vision
  • 3.  RE: Playing clips as animated wipe
    Posted 06-17-2016 21:17
    Nexio AMP
    #Vision
  • 4.  RE: Playing clips as animated wipe
    Posted 06-17-2016 21:38
    You will have to check with Harris as to what Codec with Alpha channel that they support as the Nexio is a Harris server not a Ross Product.
    #Vision
  • 5.  RE: Playing clips as animated wipe
    Posted 06-17-2016 21:59
    Will do thanks
    #Vision
