  • 1.  BlackStorm FlexDevice Driver
    Posted 09-26-2013 04:19
    In this cutsheet about BlackStorm: http://www.rossvideo.com/pdf/cutsheets/vision-interface/video-servers/Video-Server_Ross%20BlackStorm%20(ethernet-AMP)%20(4999DR-161F-01).pdf
    There are instructions on how to setup the BlackStorm as a FlexDevice, but we're running into a problem at Step 5:
    5. Locate the FlexDevice driver file VidServ-AMP-Eth-#.#-
    ###.tar.gz
    Where does one obtain this driver file?
  • 2.  RE: BlackStorm FlexDevice Driver
    Posted 09-26-2013 08:12
    Hi Tyler,
    Give tech support a call at 613-652-4886 and they can get you a download link.
    Also you can set it up as vdcp over Ethernet and that will also work.
    #Vision
