You can set them up in the menus. From page 34 of the setup manual:
[QUOTE]
DVE/FSFC Resources (Carbonite Frame Only)
The Carbonite frame can support a limited number of DVE channels, FSFCs, and MiniMETM outputs. The switcher must be rebooted to switch between the two resource modes.
To Switch Between DVE/FSFC Resource Modes
[LIST=1]
Press MENU>SYSTEM>NEXT>NEXT>
NEXT > NEXT.
Use the D/F/M knob to select the reesource mode.
8/0/4 "” provides 8 channels of DVE, 0 FSFC resources, and 4 MiniMETM resources
4/6/0 "” provides 4 channels of DVE, 6 FSFC resources, and 0 MiniMETM resources
Press D/F/M > Reboot to apply the changed.
The switcher reboots to apply the changes to the resources.
