I am troubleshooting a problem with a piece of gear connected to the output of my MDX switcher.
Looking at the output on my Tektronix scope I noticed the scope said the switcher output switched between 8 and 10 bit depending on the crosspoint selected.
Black reads as 8 bit. My cameras are 10. Color backgrounds are 8 or 10. And doing a slow dissolve to black the output switches back and forth between 8 and 10.
Is this changing normal? Is my scope correct in its readings?
