Hi Scott,
Okay so you need to go into the hardware setup of the XPression and then go to the physical output cards.
Click on them so they bring up the board configuration.
On the reference tab use these settings:
Vertical to -2 and then set the Horizontal anywhere between 8000ns and like 37000ns. You will get them to line up just fine.
#Vision
