  • 1.  Edit Tally And/Or Busmap Changes in Next Software Update?
    Posted 01-11-2014 09:55
    Hi gals,
    Is there any future plans for being able to change the Tally config and/or the Busmap (particularly the Busmap!) setup through Dashboard? We have 5 systems that are constantly being used by several different technicians (on many different type of jobs) and it can quickly get boring shifting the busmap with 2 dials and a pushbutton function.
    As a postscript, I know I should have my setups stored on a USB .....but I just keep forgetting to do this.
    Thanks.
  • 2.  RE: Edit Tally And/Or Busmap Changes in Next Software Update?
    Posted 01-11-2014 13:30
    Yes we plan on adding everything as the releases continue.
    Tally and bus map are not in version 8 due out by the end of the month but we did add custom control naming and menu editing -- this is to emulate the same menu functions not allow for offline creation and editing. You still need to be connected to the switcher.
