  • 1.  Media-Store Animations
    Posted 02-16-2012 03:39
    I'm using a carbonite in 576i/50 mode software 5.1.0.6078
    When using a media transition, the transition flashes the cut frame at the end of the transition. For example, I have a 23 frame animation and the cut fr set to 11. the transistion runs, and the last flash is of frame 11.
    Does anyone else have this issue, and does anyone have a work around?
    We go live with the desk for the first time in 25 hours so would be great to get an solution if possible,
  • 2.  RE: Media-Store Animations
    Posted 02-16-2012 03:55
    Hi Sam,
    Under the System Menu you will find a Switch Field. Change it to F1 and you will be good.
  • 3.  RE: Media-Store Animations
    Posted 02-16-2012 04:06
    thanks for the quick reply - fixed it.
    Sam
