I'm switching on a Vision 2M with XPression running CGs. I would like to be able to send the "resume" command each time I take a CG channel on-air, similar to the way you can trigger a GPI when a specific source is taken. Before you ask, no, we're out of GPIs to use for this (Vision is integrated into our automation system via GPI).
For example, I have a lower 3rd ready in CG-1, a sponsor billboard in CG-2, a pre-built animation for a story in CG-3, and an intersticial in CG-4. Is there any way for me to have the Vision tell CG-1 to resume if I take it via the keyer module, CG-2 when I take it live in an MLE with a sponsor background, 3 when the script calls for it as it's being keyed into the background of another MLE, and 4 when I take the keyer module full in order to start the transition.
I can do this via SS (or like I said, GPI if I had more available), but I'd like to do this via serial to XPression, instead.
Any ideas? Thanks!
