Les,
It has been a little since we last visited this issue. We retrograded to 7.3.4 and have just now had a chance to revisit 8.0.3.
I have the same issue but with greater detail. I've narrowed down the problem to just the media store. Whenever a still or animation goes to air as a direct source, there is one single green line at the top of the frame. However, if I run it through a dve key, no green line.
I tried using a mini me with M1 through a DVE key, but still had a green line.
System config is still the same. Carbonite 2M -> Vista Spyder -> LED Processing
One more detail is on my Marshall QC monitor there is no green line, but through the Vista Spyder, there is.
My thought is that the Marshall is cutting off 1 or more pixels even though its says "Native" and the Spyder is more pixel accurate.
Thoughts? Thanks for your help.
Iain
