Less I have in my system a Hyper Deck Black Magic and the output of the SDI HD signal include the audio embedded, I need to know if the Carbonite 2 can use this signal without problem with the audio embedded.
Let me know if that can be use if let me know if the SDI signal after pass of the carbonite switch it will continue with the embedded audio signal.
Please give me your answer as soon as possible.
