  • 1.  File type for Media Store Animations
    Posted 06-26-2013 20:03
    What file type should I use for an animation in Media-Store?
  • 2.  RE: File type for Media Store Animations
    Posted 06-27-2013 00:51
    TARGA is used for animations in the media store.
    EDIT: apparently PNG is ok too, but I've not had success with that even on version 7.
  • 3.  RE: File type for Media Store Animations
    Posted 06-27-2013 01:25
    PNG works fine -- I use many sequences that are PNG based that I have exported from After Effects and from XPression.
  • 4.  RE: File type for Media Store Animations
    Posted 06-27-2013 01:27
    I've found that they come out as multiple files on the switcher, instead of a single animation. I'm pretty sure that I do the same thing for PNG as I do for TARGA.
  • 5.  RE: File type for Media Store Animations
    Posted 06-27-2013 12:04
    Yes they come out as Name_0000 thru Name_xxxx each is a frame and the switcher sees them as a "single item" and loads them into the ram cache
