Mike,
Just unzip the downloaded upgrade folder and copy the 'upgrade-5.1.0.6078.carbonite' file to the root of a USB drive or thumbdrive. You can then upgrade using the following proceedure:
1. Ensure that DIP switch 4 on the frame is set in the up position. If
this DIP switch is set in the down position, you will not be able to
upgrade the switcher.
2. Insert the USB drive with the upgrade file into the USB Port on the
switcher. You must wait 5 seconds for the switcher to recognize the
USB drive.
3. Press MENU > RESET > NEXT > NEXT > NEXT.
4. Press the From USB knob.
5. Use the USB knob to select the upgrade file you want to install
onto the switcher.
6. Press the USB knob.
7. Press the Confrm knob to install the selected file.
If the message CRITICAL UPGRADE is shown on the display, the
switcher is performing an upgrade that includes critical software
components. This does not indicate a problem with your switcher.
The switcher starts upgrading with the selected file. The upgrade
will take several minutes to complete.
I think you will enjoy the new version - the media manager is totally cool!
Nigel
