do you have a FSync turned on?
If a Fsync is enabled on that input -- or in Bus mode on the pgm bus the audio will be stripped as all of the Ancillary Data is stripped.
from the manual:
1. PressMENU>SYSTEM>NEXT.
2. Use the Anclry knob to select whether ancillary
data is stripped or passed.
"¢ N Strp "” ancillary data is stripped
"¢ N Pass "” ancillary data is passed unmodified
"¢ L Strp "” ancillary data and some lines of active video are replaced with black
"¢ L Pass "” ancillary data and some lines of active video are passed unmodified
So make sure also you have not set this to one of the STRP settings which will also strip all of the audio as well.
#CrossOver
