  • 1.  Chromakey
    Posted 07-01-2014 01:54
    Using the advanced setting on Ultra-chromakey, I have got our key to look almost PERFECT.... EXCEPT when the source to replace the green is fed with one which is white in color (not the subject in front of the green, but the source replacing the green). Why would the source replacing the green have an affect on how the key comes out? And how can I work on this?
  • 2.  RE: Chromakey
    Posted 07-01-2014 02:06
    Anychance you can make a video of what is going on? Also are you assessing this on a Vector or WFM? If so can you show it's changes in the video as well please?
    #Vision
  • 3.  RE: Chromakey
    Posted 07-10-2014 07:26
    Thank you Les, I sent you a video with those elements.
    #Vision
