can anyone tell me at what point the Vision's frame will shutdown, due to overheating,or at least kick the cooling fans in at a higher speed,
the reason is we had an Air Conditioner trip on us this morning so the server room was hot,after getting air working,it took a long time to get the room cool again, during the time
I checked the status screen for the vision, it said inlet air temp was 35 Celsius
which is 95 degrees Fahrenheit,fan speed was running 50% all of this was after the air was fixed,
so really hot still
is there a heat threshold?
are the fans on a sensor that will speed them up when it is too hot to operate?
