  • 1.  Function lock for Custom Control?
    Posted 09-03-2013 13:31
    Is there a way to "lock" the functionality of the bus that is used to trigger custom controls? Currently, I use custom controls to recall and trigger my replay wipes, but like to maintain the flexibility of which keyers we use going back to game action ... and selecting a keyer changes the functionality of the bus that is also used to trigger the custom controls.
  • 2.  RE: Function lock for Custom Control?
    Posted 09-03-2013 17:51
    Hi Matt,
    Under the personality - Trans Area menu you with Find a NextTr set from Follow to No Follow. Make sure to set your overall switcher state for default with the on -- then under the Reset Menu do the Save Default State so that every time you do a Reset it will keep the NoFollow enabled.
  • 3.  RE: Function lock for Custom Control?
    Posted 09-07-2013 12:23
    Thank you, Les! All set ... not sure how I missed that, I feel kind dumb. :)
    Matt
  • 4.  RE: Function lock for Custom Control?
    Posted 09-21-2013 11:02
    Les ... I did a "Save Default State", but this option always defaults to 'follow' rather than 'no follow'. I'm running 7.0 (don't remember which build) ... it's not a huge deal, I just thought I'd ask if maybe there was a software fix for this?
  • 5.  RE: Function lock for Custom Control?
    Posted 09-21-2013 14:28
    Did you save afterwards?
    If you recall the setup file it also recalls the default state and could be flipping it back.
    Yes there is a newer version but currently 7.3 will change the way your mnemonics work and won't show you the macro colour.
  • 6.  RE: Function lock for Custom Control?
    Posted 09-28-2013 10:29
    Les, thank you again for your help. I've been trying some different combinations ... making sure that I've saved the default state, then re-saving all of the components of my 'set', even storing into a new 'set' register. I still can't get the change to stick. It's easy enough for me to change when I set-up to do a show, just hard to explain to people who aren't as familiar with the switcher.
    We need to update to 7.3 for a few other improvements, so I'll likely revisit this after we install the update.
    Thank you again!
    Matt
